[Proj] Roussilhe Projection
Steffen Macke sdteffen at gmail.com
Wed Oct 19 23:06:22 PDT 2005
> > I was puzzled by the fact that libproj rouss apparently doesn't do anything
> > with the scale factor k0 (m0).
The following gives quite good results for my purposes:
cs2cs +proj=latlong +datum=WGS84 +to +proj=latlong +ellps=clrk80
+towgs84=-182.966,-14.745,272.936 +rf=293.46 | ./lproj +proj=rouss
+a=6378249.2 +lon_0="39d09'E" +lat_0="34d12'N" +k_0=0.9995341
+ellps=clrk80 +rf=293.46
Is there a way to combine the two commands in one? My attempts in this direction
failed. In the end, I would like to project the data in PostGIS. Might
the problem be related
to the k0 issue described above? (This is using Gerald Evenden's libproj)
I filed the enhancement request.
Steffen
