[Proj] Roussilhe Projection
Gerald I. Evenden gerald.evenden at verizon.net
Sun Oct 23 12:01:13 PDT 2005
A problem comes to mind with the PASCAL procedure
> > > > http://www.geonet.net.pl/gfx/pliki/kod_korekta65.txt
I presume this is a "forward" correction.
Is there an inverse correction?
Doing an inverse of a bivariate polynomial is a bit fussy.
Jerry and the low riders:Daisy May and Joshua
"The being cannot be termed rational or virtuous,
who obeys any authority, but that of reason."
---Mary Wollstonecraft 1792
