[Proj] Implementation(s) for Oblique Stereographic
Wed Oct 26 13:42:46 PDT 2005
On 10/26/05, Gerald I. Evenden <gerald.evenden at verizon.net> wrote:
> The Oblique Stereographic code in EPSG 7.2 IS NOT Roussilhe. The EPSG code
> is the Double Projection method using conformal conversion of the ellipsoid
> to the sphere and then using the spherical stereographic projection.
> Roussilhe is not mentioned in the EPSG 7.2 publication.
> Libproj4 provides for three (3) different Oblique Stereographics
> projections: "+proj=stere" for the USGS version (Snyder), "+proj=sterea" for
> the Double Projection method and "+proj=rouss" based upon Roussilhe's 1922
> paper.
> The description of the +proj=sterea projection in the libproj4 manual looks
> different from the EPSG description because the process is organized so that
> the conformal conversion software is also used by the Krovak and Swiss
> projections.
Gerald,
Thanks for your clarification. I have put it into the bug report.
  http://bugzilla.remotesensing.org/show_bug.cgi?id=980
Best regards,
