[Proj] reprojection of sites within SHP file to standard output
Tue Sep 13 17:15:53 PDT 2005
> I think also that grass gis can import SHP
> files and then export to ascii formats.
> Grass is open source.
> Unfortunately I don't have grass on this
> particular machine so I can't verify.
GRASS can do it sure (v.in.ogr, v.proj, v.out.ascii, and
v.out.ascii.db), but GRASS is just using OGR which comes with GDAL, a
half-sister product of PROJ, & you can just use OGR directly.
http://www.gdal.org/ogr/
I believe ogr2ogr is the utility you want. (use the -t_srs option)
Hamish
