[Proj] [Newbie] Conversion from wgs84 to tmerc
Roland Rickborn r_2 at gmx.net
Mon Apr 24 04:31:54 PDT 2006
Hi folks,
I'd like to convert wgs84 coordinates from all over Europe to tmerc
(Gauss-Krueger).
According to David Vaz' posting "cs2cs how to use" (posted on Feb. 15,
2006, [1]) it is not that easy to convert?!
> You cannot go directly from WGS84 Datum coordinates to a projection (tmerc)
> on another Datum without FIRST performing a Datum Shift.
Searching the web, I found the following information [2]:
> I got the same problem as Harald Wehr when tranforming from wgs84 to
> Gauss-Krueger (zone 4).
> I use cs2cs as follow
> cs2cs +proj=latlong +datum=WGS84 +to +proj=tmerc +ellps=bessel
> +lat_0=0 +lon_0=12 +x_0=4500000 +towgs84=583,68,399
Presumably, this applies (to a certain part of) Germany!?
My questions are:
how can I determine lon_0 (central meridian) and x_0 (left shift) for
many different locations in Europe? All I have are the geographic
coordinates and the geographic coordinate system. E.g.:
ID|GeographicCoordinateSystem|Longitude|Latitude|CountryID
1|"WGS84"|9.183132|53.904484|DE
2|"WGS84"|6.764922|38.33335|ES
[1] http://lists.maptools.org/pipermail/proj/2006-February/002100.html
[2] http://lists.maptools.org/pipermail/proj/2002-June/000378.html
[3] http://www.grass-gis.de/lit_html/grasshandbuch_v12/node172.html (german)
Any hint appreciated.
TIA,
Roland R.
