[Proj] Old problems
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Jan 2 12:59:58 PST 2006
Gerald I. Evenden wrote:
> Nice idea, but life is too short.  I download GRASS and managed to get all the
> necessary support stuff also installed so that 'configure' and 'make' managed
> to get though the installation process.  While trying to do a quick test with
> the included demo stuff and good 'ol Spearfishi, I ran into a hassle.  Upon
> opening the files I got a 500ms flash on the screen of some map like image
> and then GRASS TK screen disappeared and a diagnostic listing came up on the
> session window listing a bunch of "faillures" seeming to point to some
> librarie(s).
Hmm sounds like it might perhaps be a simple problem with finding the
shared libraries---you could try adding /usr/local/lib (if that's where
you installed the support stuff) to /etc/ld.so.conf and running
ldconfig, or adding /usr/local/lib to the LD_LIBRARY_PATH environment
variable.
Or add the -text command-line switch to the GRASS start-up command so it
doesn't try loading the GUI stuff at all.
But.. this isn't the GRASS list so I won't elaborate and cause undue
traffic. It took me several months to sort out all the problems and get
GRASS to compile completely when I first started using it 3-4 years ago
so up and running in 8 minutes is good going!
Paul
