[Proj] Finnish KKJ in proj 4.4.9 - Linux vs. Windows
Roger Oberholtzer roger at opq.se
Tue Jan 3 12:26:41 PST 2006
On Tue, 2006-01-03 at 10:11 -0800, Eric Miller wrote:
> Are they really in minutes?  If I divide by 60 and run through cs2cs using esri:2393, I don't get anything close to your reference values.  I also assumed you meant the values were in longitude (col 7) and latitude (col 8) order.
The values are as I described them. The first is latitude and the second
is longitude. In ddmm.mmmmm, not minutes. My mistake.
> Also, even though pj_transform assumes datum=WGS84 if no datum is specified, it'd be more correct to actually specify +datum=WGS84.
> >>> roger at opq.se 1/3/2006 5:11:21 AM >>>
> On Wed, 2005-12-14 at 15:44 +0100, Roger Oberholtzer wrote:
> Columns 7 and 8 are WGS84 lats and longs in minutes. I have verified
> that both the Linux and Windows calculations are using the exact same
> values for these. These are the values that all calculations are based
> on.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
