[Proj] proj and Dutch RD
Martin Vermeer martin.vermeer at hut.fi
Wed Jan 11 11:32:33 PST 2006
On Wed, Jan 11, 2006 at 10:09:39AM -0800, Eric Miller wrote:
> Here's a source listing 3-parameter values for transforming between WGS84 and RD: http://kartoweb.itc.nl/geometrics/Reference%20surfaces/DATUM.txt
> Rijks Driehoeksmeting=Bessel 1841,-593,-26,-478,Netherlands
> I've no idea if the signs needs to be changed or what the source is...  Caveat lector!
> Theoretically you can use the +towgs84 argument to apply the datum transformation.
Yes of course... you need the correct translation vector. The Bessel
ellipsoid is non-geocentric!
Forget my suggestion of using bessel as the 'from' ellipsoid. It should
be wgs84 with proper shift added.
- Martin
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060111/877a324a/attachment.sig>
