[Proj] Two questions about Proj
Fri Jan 20 05:59:14 PST 2006
On 1/19/06, Andy Canfield <andy.canfield at gmail.com> wrote:
> First question:
> Is there a good example somewhere of using it to transform coordinates
> from one projection to another?
Andy,
I'm not sure what qualifies as a *good* example.  A simple example
might be:
cs2cs +proj=utm +zone=11 +datum=WGS84 +to +proj +zone=12 +datum=WGS84
> Second question:
> Is there a good example somewhere of using it to shift from one datum
> to another within the same projection?
cs2cs +proj=utm +zone=11 +datum=NAD27 +to +proj=utm +zone=11 +datum=NAD83
> Third question:
> Does it support translating coordinates to and from the old AT&T V&H
> coordinate system?
This is not supported by PROJ.  I see Oscar has provided excellent
details on how you could accomplish it.
Best regards,
