[Proj] System 42/83 (S42/83)
ErichS erich.sadlowski at gmx.de
Tue Jan 31 23:00:54 PST 2006
Hello all,
I'm trying to use coordinates in S42/83, a system often used in eastern Europe
(e.g. Russia) and partially in East-Germany ("Deutsches Heeresgitter").
It's similar to Gauss-Kruger (Gauß-Krüger) (i.e a transverse mercator
projection) but it uses 6 degrees wide stripes instead of 3 degrees.
And its first meridian is at 3E.
Is there a possibility to define these parameters in cs2cs/proj4?
As ellipsoid "Krassovski" is used (+ellps=krass).
Many greetings
Erich
