[Proj] Using Azimuthal Equidistant for Great/Small Circle Generation
Rob Iverson rob.iverson at gmail.com
Wed Mar 8 10:26:15 PST 2006
Sorry for the nearly-off-topic message here!  I don't know where else to
turn...
Is it valid to use the two-hemisphere form of the Azimuthal Equidistant
projection to compute great circles and small circles?
Here's what I have been doing:  I take a point that is the "center" of the
great/small circle, use that as the projection origin for azimuthal
equidistant, take the "radius" of the great/small circle (where 90 degrees
is a great circle), generate points on a circle centered at the middle of
the map, and inverse-project each of those points to get the coordinates on
the surface of the earth.
This certainly appears to give correct results, but I have no idea if it's
valid mathematically.
If it helps, I am currently using a spherical model of the earth, but I am
interested if this technique would work with the ellipsoidal models.
Thanks for your help!
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20060308/eeef78aa/attachment.html>
