[Proj] proj/libgeotiff interaction: GTIFProj4ToLatLong()
Eric Miller EMiller at dfg.ca.gov
Thu Mar 9 11:40:46 PST 2006
You don't show how the variable "proj_is_latlong" is defined or assigned to.  If it's zero, GTIFProj4ToLatLong will not be called.  Also, if GTIFProj4ToLatLong returns zero for success (a typical return code) then your error message will print.
>>> "Curt, WE7U" <archer at eskimo.com> 3/9/2006 10:58 AM >>>
This has to do with an interaction between proj and libgeotiff, so I
don't know which list to put it to, but since it has to do with a
proj function, I'll try here.
First, the code:
  if (GTIFGetDefn (gtif, &defn)) {
    if (debug_level & 16)
      GTIFPrintDefn (&defn, stdout);
  if ( proj_is_latlong || GTIFProj4ToLatLong( &defn, 1, &xxx, &yyy ) )   // Do all 4 of these in one call?
    if (debug_level & 16) {
      fprintf(stderr,"  (%s,", GTIFDecToDMS( xxx, "Long", 2 ) );
      fprintf(stderr,"%s)\n", GTIFDecToDMS( yyy, "Lat", 2) );
      fprintf(stderr,"%f  %f\n", xxx, yyy);
  else {
    fprintf(stderr,"Failed GTIFProj4ToLatLong() call\n");
I'm getting the "Failed GTIFProj4ToLatLong() call" message four
times, once for each such call I make.
I'm using these packages:
    proj-datumgrid-1.3.zip
    proj-4.4.9.tar.gz
    libgeotiff-1.2.3.tar.gz
I verified by re-installing these just now that I installed proj
first, then installed libgeotiff, and the libgeotiff configure found
libproj just fine.
The geotiff I'm having a problem with has UTM zone 10 coordinates.
USGS DRG geoTIFF topo maps with Lat/Long coordinates (but UTM
projection) are read in just fine by my code.
Curt, WE7U.   APRS Client Comparisons: http://www.eskimo.com/~archer
"Lotto:    A tax on people who are bad at math." -- unknown
"Windows:  Microsoft's tax on computer illiterates." -- WE7U
"The world DOES revolve around me:  I picked the coordinate system!"
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
