[Proj] help with clark66 as datum
Clifford J Mugnier cjmce at lsu.edu
Fri Mar 10 07:30:27 PST 2006
The DCW - Digital Chart of the World was HAND digitized by the Defense
Mapping Agency in the early 80s from small scale "ONC" Operational
Navigation Charts.  That became the defacto FREE dataset of the world's
coastlines, rivers, etc used by all software companies including ESRI.  (It
came on a 9-Track tape from DMA as did the GCTP come on a 9-track tape from
the U.S. Geological Survey.)  The ellipsoid used as a default then was the
Clarke 1866.  That is how it wound up being used for New Zealand.  (So was
the entire world.)
You have to be old enough to be able to remember this stuff!
Very early versions of ESRI software were on Unix machines that were
running Arc/Info, long before personal computers were invented.  The
initial implementations of projection math were based on GCTP, a Fortran
translation of John P. Snyer's first book (GCTP was written by Dr. Atef
Elassal).  All examples used the Clarke 1866 ellipsoid, because that was
the legal ellipsoid in use (for the NAD27) by the U.S. Geological Survey in
the U.S. before 1983.
You merely have an ancient dataset, and you may change it to any ellipsoid
that you wish without degrading any of the data.  The Normal Mercator
projection is rarely used for large-scale mapping where an actual datum is
of importance.  The exceptions are for all of Indonesia and for the city of
Guyaquil, Ecuador.
It's not a mistake, it was correct at the time.  John P. Snyder NEVER
concerned himself with datum transformations.  He considered that datums
were geodesy and not cartography, so he deferred to me on that stuff.
(John had a Master's Degree in Chemical Engineering.)
Cliff Mugnier
LSU
I would assume that the "D_Clarke" stuff is just a mistake, and that
all they mean is a Clarke 1866 spheroid.  Does this work?
+proj=merc +lon_0=100 +lat_ts=-46 +ellps=clrk66
Paul
On 3/9/06, Hamish <hamish_nospam at yahoo.com> wrote:
> Hi,
> I'm trying to figure out PROJ.4 parameters for a newly published
> dataset that has been widely distributed down here in New Zealand.
> ERSI Shapefile .prj file that came with it:
> PROJCS["Clarke_1866_Mercator",GEOGCS["GCS_Clarke_1866",
> DATUM["D_Clarke_1866",SPHEROID["Clarke_1866",6378206.4,294.9786982]],
> PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
> PROJECTION["Mercator"],PARAMETER["False_Easting",0.0],
> PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",100.0],
> PARAMETER["Standard_Parallel_1",-46.0],UNIT["Meter",1.0]]
> Documentation that came with it:
> The projection used [...] is:
> Mercator Projection
> Central Meridian = 100
> Standard Parallel = -46
> False Easting = 0
> False Northing = 0
> Spheroid/Datum = Clarke 1866
> This confuses both me & the GRASS GIS projection auto-import tool.
> Does clark66 define a datum??
> Is this meaningful:  DATUM["D_Clarke_1866",  ??
> Should I give up and just assume +towgs84=0,0,0 ?
> I have no idea why they used clark66 or a point in the ocean 1500km SW
> of Perth Australia as the center of projection for a modern New
> Zealand
> dataset. But so it is.
> Hamish
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
