[Proj] Error compiling proj on Solaris: Undefined symbol
Adrian Holovaty adrian.holovaty at wpni.com
Fri May 19 11:04:04 PDT 2006
Hello,
I'm trying to install proj on Solaris so I can use it with PostGIS, but it
won't compile. Here's the relevant error I get when I run "make".
gcc -g -O2 -o .libs/proj proj.o gen_cheb.o p_series.o  ./.libs/libproj.so -lm
-R/usr/local/lib
Undefined                       first referenced
 symbol                             in file
.LLC4                               ./.libs/libproj.so
.LLC8                               ./.libs/libproj.so
ld: fatal: Symbol referencing errors. No output written to .libs/proj
collect2: ld returned 1 exit status
make[2]: *** [proj] Error 1
make[2]: Leaving directory `/home/holovatya/proj-4.4.9/src'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/holovatya/proj-4.4.9/src'
make: *** [all-recursive] Error 1
The same error has been pointed out here:
    http://lists.maptools.org/pipermail/proj/2006-April/002193.html
    http://lists.maptools.org/pipermail/proj/2006-February/002090.html
Those threads suggested a couple of solutions, all of which I've tried.
I've tried removing the C_NAMESPACE qualifiers, as suggested here:
    http://bugzilla.remotesensing.org/show_bug.cgi?id=298#c4
I've tried setting CFLAGS, as suggested here:
    http://bugzilla.remotesensing.org/show_bug.cgi?id=298#c6
I've tried using a custom version of libtool, as suggested here:
    http://lists.maptools.org/pipermail/proj/2006-February/002093.html
The same compilation error happens every time with each of those suggested
fixes.
I'm using:
    proj 4.4.9
    Solaris 9
    GCC 3.2
    make 3.80
Please help me get proj to compile. Thanks for any and all help, and let me
know if I left any important information out of this report.
Adrian
Adrian Holovaty
washingtonpost.com
