[Proj] Proj4 transform from WGS84 to UK Northings and Eastings help needed ...
Eric Miller EMiller at dfg.ca.gov
Tue May 23 08:24:50 PDT 2006
I'd be surprised if any ESRI product used PROJ.4.  They've been pretty adamant that their projection libraries are not based on PROJ.4.
>>> pennyb at btex.co.uk 5/23/2006 6:24:18 AM >>>
Hiya all
I have some Navteq data, which I believe is in WGS84 decimal degrees.
I am using an ESRI product (which uses proj4) to project the data
[snip]
