[Proj] Datum shifts in PROJ's EPSG table (The Netherlands and Belgium)
Thu Nov 2 07:01:56 PST 2006
Roger Oberholtzer wrote:
> On Thu, 2006-10-26 at 16:17 +0200, Oscar van Vlijmen wrote:
>> I suppose the "confirmed" transformation:
>> <quote>
>> a more accurate definition for the Dutch system is:
>> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
>> +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel  +units=m
>> +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.87
>> 03473836068,4.0812
>> +no_defs +to +proj=latlong +datum=WGS84
>> </quote>
> OK. Given these values, how would one do this using the C API, and the
> pj_transform() function. Starting with WGS84 lat/long values as provided
> by a GPS receiver set to provide WGS84 values?
> I know that I am asking numerous similar C-API question on this list,
> but I do not really feel I have it sorted out in my mind.
> Would it be:
> fromProj = pj_init_plus(+proj=latlong +ellps=bessel)
> toProj   = pj_init_plus(
> 		"+proj=sterea +lat_0=52.15616055555555
> 		"+lon_0=5.38763888888889
> 		"+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
> 		"+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.87
> 		+units=m +no_defs)
> pj_transform(fromProj, toProj, 1, 0, &lng, &lat, &alt)
Roger,
There are several missing double quotes in the above example.
I think the fromProj should also be "+proj=latlong +datum=WGS84".
As you have expressed it now, pj_transform() will see no need for a
datum or ellipsoid conversion since the source and destination are
both on the bessel ellipsoid and no datum info was provided for the
source.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
