[Proj] conversion latlong to UTM (& vice versa)
Oscar van Vlijmen ovv at hetnet.nl
Thu Nov 2 15:41:52 PST 2006
> From: oon-informatika.org
> Date: Thu, 02 Nov 2006 16:22:44 +0700
> Subject: [Proj] conversion latlong to UTM (& vice versa)
> If I convert from latlong projection to UTM projection,
> I can get the UTM zone from UTM definition, so I can calculate the zone
> from it's longitude.
> If I'm doing vehicle tracking with UTM projection,
> and the vehicle moving between UTM zones,
> How should I do to get UTM zone of current position of vehicle?
> (so I can convert UTM to latlong again).
> Is it any statement or definition of UTM that declare
> how to get UTM Zone from UTM coordinate?
I believe it is not possible to derive from the UTM coordinates the zone
number.
For instance,
lat=35, lon=113, zone=49 (central meridian = 111)
gives UTM coordinates (x,y):
682516, 3874871
Exactly the same UTM coordinates are produced for:
lat=35, lon=119, zone=50 (central meridian = 117)
So, there is only one option: convert back from UTM with known zone number
to lat,lon and reconvert in the other zone to UTM.
Or, set the tracking system to lat,lon production!
