[Proj] Datum shifts in PROJ's EPSG table (The Netherlands and Belgium)
Oscar van Vlijmen ovv at hetnet.nl
Fri Nov 3 07:41:00 PST 2006
> From: Roger Oberholtzer
> Date: Fri, 03 Nov 2006 11:34:01 +0100
> Subject: Re: [Proj] Datum shifts in PROJ's EPSG table (The Netherlands and
> Belgium)
>> If you could provide a clear numerical example with enough significant
>> digits of what is expected, then there is some hope someone will be able to
>> give some clues.
> You seem like they type of guy who may have a few WGS84 lat/longs in
> degrees and the corresponding RD northings and eastings that should
> result. Or perhaps you have a pointer to a site that has such items? I
> can then fiddle with this to get what I need, leaving the list in peace
> for a bit.
To start with, see the archive:
<http://lists.maptools.org/pipermail/proj/>
and my (Oscar) posting dated 2006-01-12
"Re: [Proj] proj and Dutch RD"
with lots of references and examples.
Note that there are no published official test points I know of with the
2004+ transformation parameters, as discussed recently on this list.
