[Proj] Re: Re: Proj4 Bug (rtodms)
Wed Nov 8 10:20:09 PST 2006
cp wrote:
> After these rights observations, I look at more seriously this portion of
> code.
> So the problem is staying for all people who are working with Borland
> environment or with code optimization and  r / 60. give a false result.
> In Last, thanks for all constructors of proj4 and BRAVO for the work
> accomplished.
Folks,
I haven't heard any statement that the proposed change was harmful, did
I miss anything?
If not, then I think the change is worth applying on the basis that it
makes the results right even if some compilers are applying questionable
optimizations.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
