[Proj] Is there any Java compatibility ??
Wed Oct 25 04:52:12 PDT 2006
> Can I use proj4 lib functions in a Java program ??
Sandeep,
The PROJ source tree includes JNI based Java bindings.  I have
attached the README from proj/jniwrap, but basically if you configure
with the --with-jni option properly, you should get jni wrappers.
The GeoTools projects also includes pure Java projections classes if
a JNI wrapped PROJ seems inconvenient.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20061025/866b356d/attachment.ksh>
