[Proj] Reprojection help for a newbie
Richard Chirgwin rchirgwin at ozemail.com.au
Fri Aug 10 21:40:20 PDT 2007
Greetings,
I'm using Grass-GIS, but with a reprojection I was told this list was
the best place to go.
I have a lot of existing maps using a simple lat-long location in AGD84
- that is, Australian ellopsoid, zone 0.
I'm now trying to import some maps that were put together using the
Lambert Conformal Conical projection with the following project info:
Lamberts Conformal Conic, 3, 13, 7, 134, -27, -15, -39, 5000000, 5000000
I can't get the LCC-based map to reproject into the lat-long region and
display correctly. I've tried cs2cs, but the LCC map is still
out-of-shape compared to the ADG84 map. So clearly I'm doing something
wrong. Can anyone tell me the correct use of cs2cs for reprojecting in
and out of LCC?
Richard
More data if needed:
- For the LCC maps, the pointsfile contains lat-long columns, so I can
get a file that looks like this:
(x, y, x1, y1)
4984067.30681393 5349948.72155986 133.82 -23.77
- However, for the lat-long files, I only have lat-long data (not the
corresponding x-y values which would easily locate the lat-long info in
the LCC space).
- As well as cs2cs, I have tried georectifying the points file towards
the LCC projection, without success.
