[Proj] pj_transform arguments
Tue Aug 21 10:56:08 PDT 2007
Sue Dettling wrote:
> Hi,
> I just installed the debian version of the library.
> The man pages are out of date with the argument list
> for pj_transform. Can you tell me what the data_offset
> is ?
Sue,
I assume you mean "point_offset"?
int pj_transform( PJ *srcdefn, PJ *dstdefn, long point_count, int point_offset,
                   double *x, double *y, double *z )
In this case point_offset is the step size to use from one value to the
next in x, y and z arrays.  Normally this is 1, indicating that the values
are tightly packed one after the other.  But some folks have their values
in arrays of x/y/z interleaved, so they might pass a point_offset value
of three.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
