[Proj] Strange results utm to aeqd projection
remedius remedius at mail.ru
Mon Aug 27 01:04:54 PDT 2007
I just use cs2cs utility to transform point from utm to aeqd projection. Proj version is 4.4.9.
I have the following command line:
+proj=utm +zone=15 +ellps=GRS80 +units=m +to +proj=aeqd +lat_0=-80 +lon_0=-100 +x_0=0 +y_0=0 +ellps=GRS80 +units=m
and  try to transform (484236, 5006526) point.
The result is (631024, 6129620). I suppose It's wrong.
Then I try  to transform point (631024, 6129620) with the same command line but with -I flag.  The result is (329673, -2729005). It's  all right.
Please, any suggestions?
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070827/d4c2fa34/attachment.html>
