[Proj] Re: C API to calculate distances
Oliver Eichler oliver.eichler at dspsolutions.de
Fri Feb 9 07:33:10 PST 2007
Hi Frank
> Those changes have not been applied in CVS yet.  You should be able to
> patch your local copy of 4.5.0 based on the instructions in the report.
> I'd appreciate a note if it works well.
Ok, I'll try to find some time to do a test this weekend. However I
really need this as a release version to add it to my application
(QLandkarte). I hardly can ask everyone to patch the projection lib :)
regards,
Oliver
