[Proj] Lat-Long to Lambert Conformal Conic(2SP) transformation inaccuracy issue
Gerald I. Evenden geraldi.evenden at gmail.com
Sat Feb 17 13:22:42 PST 2007
On Saturday 17 February 2007 2:05 pm, Tonu Lukk wrote:
> Hello all
> I'm trying to convert between lag-long and Lambert Conformal Conic (2SP)
> projection.
> The command line is:
> proj +proj=lcc +lat_1=58N +lat_2=59d20'N +lat_0=57d31'03.19415"N
> +lon_0=24E +x_0=500000 +y_0=6375000 +ellps=WGS84 -r
> The problem is that when I input the origin's coordinates,
> lat=57d31'03.19415"N lon=24E, I get x=500000 ja y=6375098.83, not x=500000
> y=6375000 as coordinate system's definition suggests - a 98.83m inaccuracy
> in northing value.
> What I'm doing wrong?
The ' and " in the runline are screwing up the shell so that it is not
interpreting the DMS values properly.  A common error.
The following script gens the expected values:
lproj +proj=lcc +lat_1=58N +lat_2=59d20N +lat_0=57d31\'03.19415N +lon_0=24E
+x_0=500000 +y_0=6375000 +ellps=WGS84  <<EOF
24e 57d31'03.19415"N
EOF
gives:
500000.00       6375000.00
Note: I removed the -r because I initially got whacko values because I am so
used to putting longitude first.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939)  British psychologist
