[Proj] Proj4 for Macintosh
William Kyngesburye woklist at kyngchaos.com
Thu Jan 4 07:11:28 PST 2007
I have PROJ available built as a Universal framework, with
executables.  There is also a companion Xcode project if you like to
build things yourself.
Otherwise, PROJ is a VERY easy build from source - configure-make-
install, no configure options needed.  No Fink needed.
A universal build is tricky, due to an endian problem in the NAD
files.  My Xcode project takes care of patching the source.  I'm not
sure Fink does (I don't know if Fink does universal at all, in which
case it wouldn't matter).  A configure-make-install for your Mac
processor won't have endian problems.
On Jan 4, 2007, at 8:24 AM, Sorokine, Alexandre wrote:
> Peter,
> Proj4 is one of the packages available with Fink.  It includes both
> executable and a share library.  The package web page is here:
> http://pdb.finkproject.org/pdb/package.php/proj
> Alex Sorokine, Ph.D. <sorokina at ornl.gov>
> Oak Ridge National Lab
>> -----Original Message-----
>> From: proj-bounces at lists.maptools.org
>> [mailto:proj-bounces at lists.maptools.org] On Behalf Of Peter Bogaert
>> Sent: Thursday, January 04, 2007 6:11 AM
>> To: proj at lists.maptools.org
>> Subject: [Proj] Proj4 for Macintosh
>> Dear all,
>> Does anyone have some experience with using the proj4 on Mac
>> OS X. If so,
>> could you give me some notes on compiling the source code
>> into a library. Or
>> does there exist an object library which is precompiled and
>> can be linked
>> with other programming languages?
>> Kind regards
>> Peter Bogaert
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
