[Proj] C API to calculate distances
Michael P Finn mfinn at usgs.gov
Mon Jan 22 09:22:37 PST 2007
Oliver,
Sounds like you want to use the Vincinty calculations for geodesic
distance. Try one of these sites:
http://www.movable-type.co.uk/scripts/LatLongVincenty.html or
http://www.ga.gov.au/geodesy/datums/vincenty_inverse.jsp
Mike
Michael P. Finn
Research Cartographer
National Geospatial Technical Operations Center
U. S. Geological Survey
Rolla, MO
(573) 308-3931
mfinn at usgs.gov
http://carto-research.er.usgs.gov/
Oliver Eichler <oliver.eichler at dspsolutions.de>
Sent by: proj-bounces at lists.maptools.org
01/22/2007 05:14 AM
Please respond to
oliver.eichler at dspsolutions.de; Please respond to
"PROJ.4 and general Projections Discussions"    <proj at lists.maptools.org>
To
cc
Subject
I wonder if there is a C API to calculate the real great circle distance
of two points on a WGS84 ellipsoid. I know there is "geod" on the
command line. I had a look at it's source code however this looked quite
complicated. As this must be a standard problem isn't there something
like;
distance(p1,p1, d, dir)
p1:  point 1
p2:  point 2
d:   distance
dir: direction in degrees
Oliver
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070122/e1dd42a6/attachment.html>
