[Proj] what is wrong with unit Foot?
    Gennady Khokhorin
    gok at aerometric-ak.com
    Tue Jan 23 10:40:42 PST 2007
Hello, PROJ!
Was testing gdalwarp converting images from one coord. system to another and found that using WKT
in form of esri' .prj file is producing Unknown units on result image if .prj contains UNIT["Foot_US", 0.3048].
As a result it is interpreted as a meters and output image seats in wrong position.
Using projections with units Meter is fine.
Command line for the test:
gdalwarp.exe -rn -co "INTERLEAVE=PIXEL" -co "COMPRESS=LZW" -t_srs "ESRI::c:\shared\NAD 1983 StatePlane Alaska 4 FIPS 5004 (Feet).prj" -dstnodata 255 i61147a1_utm.tif i61147a1_asp.tif
Test image i61147a1_utm.tif (36Mb): ftp://aerometric-ak:amak2014@ftp.aerometric-ak.com (gok/ImageProcessing folder)
Did somebody experienced the same problem? Is there any work around or it is just a bug/limitation?
Thanks in advance,
Gennady
More information about the Proj
