[Proj] Error to convert latlong to lambert2et
Yves Jacolin yjacolin at free.fr
Wed Jun 13 11:25:41 PDT 2007
Thanks steberi, you are right ! The complete proj command line is working.
My 27572 code is different from your's (lon_0=0 and some other things). My
proj version is :
$ proj
Rel. 4.5.0, 22 Oct 2006
Regards,
Y.
PS : sorry for the last mails ;-)
Le Mercredi 13 Juin 2007 15:48, t steberi a écrit :
> Hi,
> You can check you have this definition in your epsg file:
> # NTF (Paris) / Lambert zone II
> <27572> +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=2.33722917 +k_0=0.99987742
> +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356515 +pm=paris +units=m
> +no_defs  no_defs <>
> You can also try the explicit command line
> proj +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=2.33722917 +k_0=0.99987742
> +no_defs -S -r test_file.txt The result (with proj4.5) should be
> 594815.06       2424247.30
> Regards,
> Thomas
> > De: Jacolin Yves <yjacolin at free.fr>
> > A: proj at lists.maptools.org
> > Objet: [Proj] Error to convert latlong to lambert2et
> > Date: Tue, 12 Jun 2007 10:33:50 +0200
> > Hi,
> > I tried to used proj4 to convert WGS84 data to lambert 2 etendue (french
> > projection, EPSG:27572). Actually, I used a php script that I wrote using
> > an
> > algorithme written in a pdf share by French IGN [1], which is correct.
> > If I try proj4 using the following code:
> > proj +init="epsg:27572" -S -r
> > 48.816667 2.266667
> > 766532.74       2426646.42
> > The new data: (766532.74,2426646.42) is not correct. The first should be
> > something like 594868, the second one seems correct.
> > Where do I may wrong?
> > Regards,
> > Y.
> > [1] <a
> > href=http://www.ign.fr/telechargement/MPro/geodesie/CIRCE/NTG_71.pdf>http
> >:// www.ign.fr/telechargement/MPro/geodesie/CIRCE/NTG_71.pdf</a>--
> > Yves Jacolin
> > <a
> > href=http://softlibre.gloobe.org>http://softlibre.gloobe.org</a>_________
> >___ ___________________________________
> > Proj mailing list
> > Proj at lists.maptools.org
> > <a
> > href=http://lists.maptools.org/mailman/listinfo/proj>http://lists.maptool
> >s.o rg/mailman/listinfo/proj</a>
Yves Jacolin
http://yjacolin.gloobe.org
