[Proj] Re: Could not load proj.dll
Tamas Szekeres szekerest at gmail.com
Thu Mar 22 12:39:22 PDT 2007
Would you check whether
http://mapserver.gis.umn.edu/docs/howto/mapscriptcscompile#unable-to-load-dll-mapscript
applies to your problem?
Tamas
2007/3/22, Hallgren Johan E <jhhal at wmdata.com>:
> Hello
> I have created a web-application under DOTNET 2.0 and IIS using proj.dll
> (the proj.dll is old and NOT compiled under DOTNET 2.0). It runes fine on my
> computer but when I deploy it to a Windows Server 2003 it fails when call
> the DllImport.
> [DllImport(@"Proj.dll", EntryPoint="pj_init_plus")]
> The error message is Could not load dll, not found…
> My guess is that there is some sequrity issue. Does anyone have clue what it
> could be about? The only dependency is MSVCR71.dll. I don't know if that
> could be a problem?
> Does we always need the manifest-file in DOTNET 2.0?
> Could it be something with the acount running IIS?
> /Johan
> ___________________________________
> Johan Hallgren
> WM-data a LogicaCMG company
> Pelle Bergs backe 3
> Box 1938, 791 19 Falun
> Tel: 023-547 46 (int: +46-2354746)
> Mobil: 070-588 44 28 (int: +46-705884428)
> johan.e.hallgren at wmdata.com
> http://www.wmdata.se
