[Proj] Could not load proj.dll
Hallgren Johan E jhhal at wmdata.com
Fri Mar 23 03:12:12 PDT 2007
It was the MSVCR71.dll that could not be found. It had to be copied from
the windows directory.
Thanks
Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Eric Miller
Sent: den 22 mars 2007 22:53
To: Tamas Szekeres; proj at lists.maptools.org
Subject: Re: [Proj] Could not load proj.dll
I believe MSVCR71.dll is installed on Windows Server 2003 out of the box
so that shouldn't be the problem.  I have a vague recollection of
running into the same problem at one point and forget what I did to fix
it.  I think it was a file permissions problem.
I have an ASP.NET 2.0 webservice based on proj that runs on Windows
Server 2003 boxes.  I specifically compiled proj.dll with VS.NET (2003)
to avoid the MSVCR80.dll and related manifest issues.  So, that
shouldn't be your problem.
>>> On 3/22/2007 at 12:03 PM, "Hallgren Johan E" <jhhal at wmdata.com>
wrote:
> Hello
> I have created a web-application under DOTNET 2.0 and IIS using
proj.dll
> (the proj.dll is old and NOT compiled under DOTNET 2.0). It runes
fine
> on my computer but when I deploy it to a Windows Server 2003 it
fails
> when call the DllImport.
> [DllImport(@"Proj.dll", EntryPoint="pj_init_plus")]
> The error message is Could not load dll, not found...
> My guess is that there is some sequrity issue. Does anyone have clue
> what it could be about? The only dependency is MSVCR71.dll. I don't
know
> if that could be a problem?
> Does we always need the manifest-file in DOTNET 2.0?
> Could it be something with the acount running IIS?
> /Johan
> Johan Hallgren
> Pelle Bergs backe 3
> <BLOCKED::mailto:johan.e.hallgren at wmdata.com>
> <BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
