[Proj] wgs point (lat-lon 'degres' to N-E 'metric')
Andrew Williams awilliams at rapidmap.com
Mon Mar 26 22:47:12 PDT 2007
Massimo,
This looks like an NMEA GPS format. Eg DDDMM.mmmmm
You might need to re-format the values to something like decimal degrees
(DDD.dddddddddd) or DD MM SS.ss to use proj for the conversion.
Regards
Andrew
-----Original Message-----
From: Massimo Di Stefano [mailto:massimodisasha at yahoo.it]
Sent: Tuesday, March 27, 2007 11:03 AM
To: proj at lists.maptools.org
Subject: [Proj] wgs point (lat-lon 'degres' to N-E 'metric')
hi,
i've a lat-lon data (wgs)
like :
4051.1749  N   01415.5317   E
is in proj a method to transform this data in a metric format ?
thanks for any suggestion about.
Massimo.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
