[Proj] mercator projection to spherical ellipsoid from WGS84
Wed Mar 28 10:58:39 PDT 2007
Scott Ellington wrote:
> Hi,
> Thanks for your response.  As I replied earlier, it appears in the latest
> versions of proj that you cannot avoid the datum transformation simply by
> removing the towgs84 parameter.  I am wondering if there is now a way to
> avoid the datum transformation without setting the input ellipsoid to match
> the output...
Scott,
I don't think there is in a single cs2cs command, but if you really just want
to go from one projection to it's corresponding lat/long, and then from that
lat/long to projected coordinates on another datum/ellipsoid without doing
anything to the lat/long values, then you should chain it as two operations.
eg.
cs2cs +proj=utm +zone=11 +datum=WGS84 +to +proj=latlong +datum=WGS84
  | cs2cs +proj=latlong +ellps=sphere +to +proj=merc +ellps=sphere
This accurately represents what you want to do.  It could also be done
with two proj commands instead of using cs2cs.
I do think the whole issue of what cs2cs does to get from one datum/ellipsoid
to another when there is no useful transformation information needs to be
revisited.  It is causing no end of problems.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
