[Proj] mercator projection to spherical ellipsoid from WGS84
Scott Ellington scott.ellington at goisc.com
Wed Mar 28 13:13:57 PDT 2007
Filed:
http://bugzilla.remotesensing.org/show_bug.cgi?id=1533
Scott
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: Wednesday, March 28, 2007 2:59 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] mercator projection to spherical ellipsoid from WGS84
Scott Ellington wrote:
> Hi Frank,
> Thanks for responding.  Unfortunately, the issue manifests itself in
> mapserver so I don't think I can chain two commands together.
> As for revisiting this issue, I think this would be helpful.  At the very
> least, I'd like the ability to avoid the datum transform as it used to be
> possible to do.  I can file a bug to keep this on the radar if you'd like.
Scott,
I see what you mean.  OK, file a ticket against PROJ.4.
I'm interested in suggestions from the community on what pj_datum_transform()
ought to do when the source and destination coordinate systems have different
ellipsoids, but one, the other, or both lack a definition of how to get
to WGS84.
Currently the code looks like this, which I hope is reasonably understandable
based on function names and comments.
int pj_datum_transform( PJ *srcdefn, PJ *dstdefn,
                         long point_count, int point_offset,
                         double *x, double *y, double *z )
     double      src_a, src_es, dst_a, dst_es;
     int         z_is_temp = FALSE;
     pj_errno = 0;
/*      Short cut if the datums are identical.                          */
     if( pj_compare_datums( srcdefn, dstdefn ) )
         return 0;
     src_a = srcdefn->a;
     src_es = srcdefn->es;
     dst_a = dstdefn->a;
     dst_es = dstdefn->es;
/*      Create a temporary Z array if one is not provided.              */
     if( z == NULL )
         int	bytes = sizeof(double) * point_count * point_offset;
         z = (double *) pj_malloc(bytes);
         memset( z, 0, bytes );
         z_is_temp = TRUE;
#define CHECK_RETURN {if( pj_errno != 0 && (pj_errno > 0 ||
transient_error[-pj_errno] == 0) ) { if( z_is_temp ) pj_dalloc(z); return
pj_errno; }}
/*	If this datum requires grid shifts, then apply it to geodetic   */
/*      coordinates.                                                    */
     if( srcdefn->datum_type == PJD_GRIDSHIFT )
         pj_apply_gridshift( pj_param(srcdefn->params,"snadgrids").s, 0,
                             point_count, point_offset, x, y, z );
         CHECK_RETURN;
         src_a = SRS_WGS84_SEMIMAJOR;
         src_es = SRS_WGS84_ESQUARED;
     if( dstdefn->datum_type == PJD_GRIDSHIFT )
         dst_a = SRS_WGS84_SEMIMAJOR;
         dst_es = SRS_WGS84_ESQUARED;
/*      Do we need to go through geocentric coordinates?                */
     if( src_es != dst_es || src_a != dst_a
         || srcdefn->datum_type == PJD_3PARAM
         || srcdefn->datum_type == PJD_7PARAM
         || dstdefn->datum_type == PJD_3PARAM
         || dstdefn->datum_type == PJD_7PARAM)
/*      Convert to geocentric coordinates.                              */
         pj_geodetic_to_geocentric( src_a, src_es,
         CHECK_RETURN;
/*      Convert between datums.                                         */
         if( srcdefn->datum_type == PJD_3PARAM
             || srcdefn->datum_type == PJD_7PARAM )
             pj_geocentric_to_wgs84( srcdefn, point_count, point_offset,x,y,z);
             CHECK_RETURN;
         if( dstdefn->datum_type == PJD_3PARAM
             || dstdefn->datum_type == PJD_7PARAM )
             pj_geocentric_from_wgs84( dstdefn, point_count,point_offset,x,y,z);
             CHECK_RETURN;
/*      Convert back to geodetic coordinates.                           */
         pj_geocentric_to_geodetic( dst_a, dst_es,
         CHECK_RETURN;
/*      Apply grid shift to destination if required.                    */
         pj_apply_gridshift( pj_param(dstdefn->params,"snadgrids").s, 1,
         CHECK_RETURN;
     if( z_is_temp )
         pj_dalloc( z );
     return 0;
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
