[Proj] Tansverse Mercator South Oriented question
Zindine nabble at souiki.org
Sat Mar 31 15:59:45 PDT 2007
I have the PROJCS below defined and it does not get validated by OGR.
I receive the error: OGRERR_UNSUPPORTED_SRS.
It was simply defined as follow:
	OGRSpatialReference    oTMSO;
	oTMSO.SetProjCS("TMSO Zone 29 / WGS84");
	oTMSO.SetWellKnownGeogCS( "WGS84" );
	oTMSO.SetTMSO(0,29,1,0,0);
Can anyone help me find the error? Thanks.
PROJCS[
		"unnamed"
		,GEOGCS[
			"WGS 84"
			,DATUM[
				"WGS_1984"
				,SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]]
				,TOWGS84[0,0,0,0,0,0,0]
				,AUTHORITY["EPSG","6326"]
			,PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]]
			,UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]]
			,AXIS["Lat",NORTH]
			,AXIS["Long",EAST]
			,AUTHORITY["EPSG","4326"]
		,PROJECTION["Transverse_Mercator_South_Orientated"]
		,PARAMETER["latitude_of_origin",0]
		,PARAMETER["central_meridian",29]
		,PARAMETER["scale_factor",1]
		,PARAMETER["false_easting",0]
		,PARAMETER["false_northing",0]
View this message in context: http://www.nabble.com/Tansverse-Mercator-South-Oriented-question-tf3499417.html#a9773150
Sent from the PROJ.4 mailing list archive at Nabble.com.
