[Proj] GDM2000 for Malaysia
Tue May 8 07:05:29 PDT 2007
Bjørn Krangnes wrote:
> I am using GDAL 1.4.0 and C#.
> I am getting other coordinate transformations to work.
> The TransformPoint function returns no status (void function).
> You are saying that my proj strings are ok.
> How should I proceed to sort out my problem ...
Bjørn,
First, it does not appear the problem is related to GDAL or C# since
people get the same results with cs2cs which is a much more direct
connection to the proj libraries.  So I think you can focus here on
why you get the wrong results from cs2cs.
You have posted the issue here, and clearly at least a couple people
have looked at it quickly with no obvious solution.
I can see two further steps:
  o You can dig up papers on the coordinate system in question and try to
    understand the parameters better and see if you can come up with a
    better PROJ.4 string to represent the parameters.  Possibly this would
    invole comparing how this projections works in other systems.
  o You could attempt to commercially engage someone to help you with the
    problem.  Possibly you could interest Gerald in the issue with some
    inducement.  I might be willing to take a crack at it on a
    no-risk-if-I-fail basis.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
