[Proj] cs2cs and Visual Basic .NET
Tamas Szekeres szekerest at gmail.com
Sat May 12 11:16:49 PDT 2007
If you want to use cs2cs exterally, you might use the
System.Diagnostics.Process to spawn cs2cs in your application.
If you want to implement similar functionality internally you might
use the SpatialReference and GeoTransformation classes from the
GDAL/OGR .NET API. You might add a reference to ogr_csharp.dll or
osr_csharp.dll in your application.
The FWTools package contains the binaries for using this functionality.
http://test.gdal.org/fwtools/FWTools130.exe
Best regards,
Tamas Szekeres
2007/5/12, Leonidas <leonidas_liakos at yahoo.gr>:
> How can I use cs2cs in my Visual Basic .NET?
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
