[Proj] Re: cs2cs and Visual Basic .NET
Tamas Szekeres szekerest at gmail.com
Mon May 14 03:53:31 PDT 2007
I guess some of the dependent dll-s could not be loaded. You might
want to copy at least
*_csharp.dll,
*_wrap.dll,
gdal14.dll
proj.dll
in you application folder.
You can find these items in FWTools/bin for example
Best regards,
Tamas
2007/5/14, Leonidas <leonidas_liakos at yahoo.gr>:
> I tried to declare a new SpatialReference object and I get an
> TypeInitializationException.
> I declare the object using VB.NET like that
> Dim src As SpatialReference = New SpatialReference("")
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
