[Proj] possible memory leak in pj_free ??
dettling at ucar.edu dettling at ucar.edu
Sat Nov 3 14:43:49 PDT 2007
Hi Frank,
The systems administrators assure me we have the latest version.
Do you know if this fix got into the latest debian linux proj package.
Thanks for your response.
S.
> Sue Dettling wrote:
>> Hi,
>> I am using the debian linux (etch) version of proj.
>> I instantiate a projection object with the following:
>> if ( (_inputProj = pj_init(6,inputPrjArgs )) == NULL)
>>     cerr << "ProjInfo::_projectData(): ERROR: Failed to initialize
>> Proj.4 "
>> 	 << "projection object." << endl;
>>     return(1);
>> where inputPrjArgs[] = {"proj=laea", "lat_0=38", "lon_0=-98", "x_0=0",
>> "y_0=0", "units=m"}.
>> It seems to work fine based on output data.
>> I free the projection with:
>> if (_inputProj)
>>     pj_free(_inputProj);
>> In stepping through with a debugger I see that the pj_free call is made
>> however when using valgrind to check for memory leaks I get:
>> =17191== 48 bytes in 2 blocks are definitely lost in loss record 1 of 1
>> ==17191==    at 0x401D38B: malloc (vg_replace_malloc.c:149)
>> ==17191==    by 0x41ECB2B: pj_malloc (in /usr/lib/libproj.so.0.5.0)
>> ==17191==    by 0x41EA5EF: pj_authset (in /usr/lib/libproj.so.0.5.0)
>> ==17191==    by 0x41CD4A9: pj_laea (in /usr/lib/libproj.so.0.5.0)
>> ==17191==    by 0x41EC577: pj_init (in /usr/lib/libproj.so.0.5.0)
>> ==17191==    by 0x805C505: ProjInfo::_initializeProj4()
>> (ProjInfo.cc:453)
>> ==17191==    by 0x805E51F: ProjInfo::init() (ProjInfo.cc:84)
>> ==17191==    by 0x8052449: NcfReader::_getGriddedData()
>> (NcfReader.cc:683)
>> ==17191==    by 0x8052FD0: NcfReader::readFile() (NcfReader.cc:169)
>> ==17191==    by 0x80504B5: NetCDF2Mdv::_processData(char*)
>> (NetCDF2Mdv.cc:211)
>> ==17191==    by 0x80509D9: NetCDF2Mdv::Run() (NetCDF2Mdv.cc:173)
>> ==17191==    by 0x804F51D: main (Main.cc:67)
>> Are there any known or possible leaks with pj_free ?
> Sue,
> I suspect you are seeing the issue fixed in this changelog entry.
> 2007-04-04  Frank Warmerdam  <warmerdam at pobox.com>
> 	* src/PJ_laea.c: Fix memory leak of apa field.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
