[Proj] Problem in calling pj_transform with retutn x and y = nan
Eric Miller EMiller at dfg.ca.gov
Mon Nov 19 09:16:37 PST 2007
Check the errors pj_get_errno_ref() && pj_strerrno().  I'm guessing the library couldn't find the CONUS nadgrid file.
You should probably be including "proj_api.h" rather than "projects.h" unless you're extending the library...
>>> On 11/19/2007 at 6:52 AM, Limei Ran <lran at unc.edu> wrote:
> Hi:
> Could someone help me on solving the problem I have in calling
> pj_transform?  I am calling pj_transform to do the projection from our
> GIS software in C.  I obtained PROJ.4 and datum shift grids files.  I
> installed the software on our linux server and tested the software using
> cs2cs.  It works fine with the right output.
> I compiled our software with the built PROJ.4 library using the lines in
> our Makefile:
> #set PROJ.4 libary
> PROJDIR=/nas/uncch/depts/cep/emc/lran/soft/proj-4.5.0/exe/lib
> PROJ_H=/nas/uncch/depts/cep/emc/lran/soft/proj-4.5.0/src/projects.h
> # Library paths
> LIBPATH=-L. -L$(PROJDIR)
> LIBS = $(LIBPATH) -lspatial -lm -lproj -static
> allocator.exe: $(ALLOC)
>         $(CC) -o $@ $(ALLOC) $(LIBS)
> Our program is compiled without errors with PROJ.4 software.
> In my calling scripts, I set:
> setenv PROJ_LIB /nas/uncch/depts/cep/emc/lran/soft/proj-4.5.0/exe/share/proj
> The program gives the right projected x and y when from and to
> projections are different, but the datum systems are the same (both
> NAD27, NAD83, ot sphere).  But, if I give different datum for from and
> to projections, the print out of projected x and y = nan.  Here are the
> output lines:
> Input projection:
> PROJ args=+proj=lcc+datum=NAD27+lat_1=33+lat_2=45+lat_0=40+lon_0=-97
> Output projection:
> PROJ
> args=+proj=lcc+datum=NAD83+lat_1=30.000000+lat_2=60.000000+lon_0=-100.000000+
> lat_0=40.000000+units=m
> In Projection: x=1100.000 y=-11200.000    Out: x=nan y=nan
> In Projection: x=-25000.000 y=25000.000  Out: x=nan y=nan
> Basically, the data transformation parts did not give me the right
> result even though the program ran without any error.  There are many
> libary files under ./proj/lib directory.  I am wondering whether LIBS in
> my Makefile is correct.  Or, I need to set PROJ_LIB somewhere else.  I
> appreciate any help you might have.
> Thanks,
> LR
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
