[Proj] PROJ INFO
Fri Nov 30 12:10:42 PST 2007
Gerald I. Evenden wrote:
> On Friday 30 November 2007 1:32 pm, Frank Warmerdam wrote:
>> In addition to Janne's useful advice, you also need to change
>> "proj=latlon" to "proj=latlong".
> Interesting.
> Did you change other longitude items like lon_0 to long_0 also?
Gerald,
No, I did not change any existing use of lon.
> I had heard of dialects that use the pronunciation emphasising the 'g' in
> longitude but that usage seemed to me to be pretty rare.  'long' seems to
> encourage pronunciation rhyming with long---like "its a long way to
> Tipperary."
> It seems like you may have created a source for a common error by using
> the "long" form if "lon" (homonym with 'lawn') is used elsewhere.
> Alas.
Indeed, I believe you are correct.  I just carried over naming I used when
I was at PCI.
I have added "latlon" and "lonlat" as also acceptable aliases for the
same non-projection.  "longlat" and "latlong" were already both accepted.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
