[Proj] DHDN / Gauss Krueger to WGS84
Oliver Eichler oliver.eichler at dspsolutions.de
Thu Sep 20 07:11:35 PDT 2007
> I do have a coordinate in easting/northing [m] from a raster map  using
> Gauss Krüger projection and Potsdam datum. Now I would like to get the
> lon/lat coordinate on a WGS84 ellipsoid. And vice versa. I would like to
> use the proj4 C API not the command line.
Ok, further investigations condensed into something like:
pjgaukru = pj_init_plus("+init=epsg:31467");
pjwgs84 = pj_init_plus("+init=epsg:4326");
// easting / northing to lon / lat
pt = pj_inv(pt,pjgaukru)
double z = 0;
pj_datum_transform(pjgaukru, pjwgs84, 1, 0, &pt.u, &pt.v, &z);
However the result is still several minutes away from the expected
coordinate. What do I miss?
Oliver
