[Proj] specifying omerc parameters
Duffy, Garret gduffy at nrcan.gc.ca
Fri Sep 28 06:06:58 PDT 2007
I am trying to specify an oblique Mercator projection using proj.4 in
GRASS.
I am looking for some advice about the valid range of the parameters
lat_1, lat_2, etc.
I am trying to specify an "omerc" as follows:
>+proj=omerc +lat_0=45.1875000000 +lat_1=-20.0000000000
> +lat_2=20.0000000000 +lon_0=0.0000000000 +lon_1=-120.0000000000
> +lon_2=-60.0000000000 +k_0=1.0000000000 +no_uoff +rot_conv +a=6378137
> +rf=298.257223563 +no_defs +towgs84=0.000,0.000,0.000
GRASS support said that absolute value of lat_0 must be less than 36.
Sure enough when I put lat_0 equal 35, proj worked.  BUT then I wanted
to change the other parameter lat_1, Lat_2, etc. to achieve the required
rotation.  I would like:
Lat_1 = -20
Lat_2 = 23
Lon_1 = -120
Lon_2 = 45
(I estimated these parameters by doing a reprojection of my dataset in
Global Mapper)
But proj fails.
On a related note, what is the accepted range of the +alpha parameter in
the alternative specification of omerc?
Any advice would be appreciated,
Garret Duffy.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070928/65604d43/attachment.html>
