[Proj] installation question: proj_api.h
Heather M. Yager heather.yager at gmail.com
Tue Aug 12 21:42:33 PDT 2008
Markus Neteler wrote:
> Heather,
> On Tue, Aug 12, 2008 at 11:01 PM, Heather M. Yager
> <heather.yager at gmail.com> wrote:
>> Hi!
>> I don't yet have experience with PROJ4, but I must install it on SuSE in
>> order to run MapServer with projection support. The problem: when I
>> install proj from an RPM (command I used: "yast -i
>> proj-4.4.9-1.guru.suse93.x86_64.rpm") it appears that the installation
>> was successful - I can locate proj, I can type "proj" at the command
>> line (and receive "Rel. 4.4.9, 29 Oct 2004" back).
> You also need to install
>  proj-devel-4.4.9-1.guru.suse93.x86_64.rpm
> which contains proj_api.h and some more relevant files.
> Hope this helps,
> Markus
Markus -
Thank you, that solved the problem in one swipe.
Cheers,
Heather Y.
