[Proj] Polar stereographic, different values on different platforms?
Bruce Raup brauplists at gmail.com
Thu Aug 21 13:12:21 PDT 2008
Eric, Frank, Glynn, Gerald, and all,
It's great to see quick action on this.  In my view, this is quite a
major bug, and it's unknown (to me) whether it affects other
projections or things that are built on top of Proj.4, like GDAL/OGR,
MapServer, etc.  It doesn't affect me directly because I use Linux,
but the colleague I'd just introduced to all these tools is getting a
bad first impression of open source geospatial software (his words).
Is there a test script already written for checking the results from
Proj.4?  If not, I will try to work up a script that tests some other
projections.
Bruce
On Thu, Aug 21, 2008 at 11:28 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Eric Miller wrote:
>> I did a little testing of various flavors of the Windows compiler.
> Eric,
> Great work!  I have filed this as:
>  http://trac.osgeo.org/proj/ticket/12
> I'll update the makefile.vc to use /Op by default, and look into updating
> at least the OSGeo4W binaries.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Bruce Raup
http://cires.colorado.edu/~braup/
