[Proj] Re: PROJ 4.6.1RC2 Available
Mikael Rittri Mikael.Rittri at carmenta.com
Mon Aug 25 07:02:55 PDT 2008
Hello,
In the ticket, Frank wrote:
> I'd like some supporting documentation indicating
> that ETRS89 is essentially equivalent to WGS84.
May I quote myself:
> However, for most practical purposes, ETRS89 can be regarded as
> identical to WGS84 ... The difference is mainly caused by the
> continental drift since 1989, which moves Europe (and ETRS89)
> about 2 cm/year towards east-northeast. Differential GPS in Europe
> will (primarily) give coordinates in ETRS89, but such coordinates
> are often called "WGS84 coordinates", in a loose sense of the word.
  (From the Carmenta Engine manual.)
My primary source is the text by the British Ordnance Survey,
http://www.ordnancesurvey.co.uk/oswebsite/gps/docs/A_Guide_to_Coordinate_Systems_in_Great_Britain.pdf
or
http://www.ordnancesurvey.co.uk/oswebsite/gps/information/coordinatesystemsinfo/guidecontents/
which, by the way, I find wonderfully clear and easy to read.
ETRS89 is described in section 4.2.4.
I admit that the guide does give some (time-dependent) 7-parameter
transformations between WGS84 and ETRS89, in section 6.5.  But as I
understand it, these would be needed only for special scientific
applications (perhaps interferometry with very long baselines, where
observatories on different continents have to cooperate.)  For everyday
mapping, ETRS89 is used.  For positioning, if you use GPS with differential
correction, you will also get ETRS89.  And if you use GPS without differential
corrections, then you will indeed get WGS84 instead of ETRS89, but the accuracy
will be worse than the (currently) half-metre difference between the datums,
so it will not matter anyway.
Best regards,
Mikael Rittri
Carmenta AB
Box 11354
SE-404 28 Göteborg
Visitors: Sankt Eriksgatan 5
SWEDEN
Tel: +46-31-775 57 37
Mob: +46-703-60 34 07
mikael.rittri at carmenta.com
www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: den 22 augusti 2008 17:04
To: Maciej Sieczka
Cc: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Re: PROJ 4.6.1RC2 Available
Maciej Sieczka wrote:
> Hi,
> Is a fix for "ETRS89-based CRSs missing datum definition" included?
> [1]http://trac.osgeo.org/proj/ticket/11
Maciek,
No, that issue is not resolved yet (as is implied in the ticket).
Best regards,
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
