[Proj] ITRF [Re: Google Earth Accuracy]
Tim Michelsen timmichelsen at gmx-topmail.de
Wed Dec 3 13:40:08 PST 2008
Hello,
> ITRF was designed to be an ultraprecise reference frame for measuring
> motions
> of the Earth as a whole, and of different parts relative to each other.
> Since
> the frame is designed to be fixed relative to the velocities of all the
> tectonic plates, averaged over the whole Earth, any particular point will
> have time-varying coordinates in this frame--as is is in fact true for any
> frame not tied to a particular plate (WGS-84 included), though many
> softwares
> do not take account of this. The people who develop and update ITRF are
> working at the millimeter level.
Would this mean that giving another person just the coordiantes recorded
from such a IRTF enabled GPS is not sufficient to convert this to WGS84
or any other projection?
I received some data in ITRF but wasn't able to transform it into WGS84,
so far. Maybe you can direct my to some examples?
Kind regards,
Timmie
