[Proj] "Double Ellipsoid" error, reproduction
Duncan Agnew dagnew at ucsd.edu
Wed Dec 10 10:00:16 PST 2008
Since proj doesn't know where its coordinates come from, +proj=merc
will do the spherical Mercator as it
stands (I assume)--no need for a new flag. I suppose this illustrates
Gerald's concerns about confusion resulting from the mixing of datums
and projections in one routine; I'll say, as a user, that it is
convenient to be able to combine datum shifts and grid conversions in
one routine, though it would be
equally convenient to separate them and use pipes. The usual problem of
path-dependence: see the QWERTY
keyboard and the 4'8.5" railway gauge.
I'll disagree with Gerald about Google Maps--their Mercator is an
excellent choice for their purpose. It is a terrible choice for a
global projection of a static map, but an excellent one at large
scales, which is where all the activity on Google Maps ends up. And for
doing preliminary locations, a familiar cylindrical projection has
merit even at a global scale. I do agree with Gerald that for a paper
global map, equal-area should be the default choice, absent some other
need.
Duncan Agnew
