[Proj] installing proj
Martin Landa landa.martin at gmail.com
Wed Jun 4 15:22:55 PDT 2008
Hi.
2008/6/5 Jeremy B <jeremyb at rental-data.com>:
>     configure
'prefix' is by default set up to /usr/local
see
./configure --help
> $ proj
> proj: error while loading shared libraries: libproj.so.0: cannot open shared
> object file: No such file or directory
so libproj.so.0 should be located in /usr/local/lib
so, add (if not present)
/usr/local/lib
to
/etc/ld.so.conf
and run
 ldconfig
(as root)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
