[Proj] FWTools and Proj: Installation
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Jun 6 10:44:30 PDT 2008
On Fri, 6 Jun 2008, Conor O'Donoghue wrote:
> Hello Frank,
> The example you gave me is just what i had in mind.
> I typed (cut-paste) your example exactly but still got an error.... as follows
> ERROR 1: Translating source or target SRS failed:
> '+proj=merc
Might be that the 'single quote' characters don't work on Windows and you
need to use "double quotes".
Paul
